04-06-2022 06:11 PM - edited 04-06-2022 06:15 PM
Is there a way to create a DataPlugIn to import CSV files with more than 200 columns? It seems that the Wizard for loading txt based data files is limited to only 200 columns.
The issue that I am having is that the very last column in my data file has a time channel and I cannot specify in the wizard to import it as a time channel. My data file contains more than 200 columns and within DIAdem, the wizard only displays up to 200 columns. So I cannot cannot specify to import the channel as a time channel as opposed to a numeric channel. Any suggestions? I am using DIAdem 2017 SP1.
04-07-2022 12:41 AM
Hi MotoDude831,
Yes, there is a limit in the numbers of columns in the DataPlugin wizard. The only way in such cases is to develop the DataPlugin by your own. For most of the ACSII files it is easy, but in the end, it depends on the complexity of the data. In the DIAdem help you find a good description and examples for creating a DataPlugin.
If you send me a few example data files I can help with that.
Greetings
Walter
04-08-2022 12:37 PM
Hello Walter,
I have attached a sample data file. I trimmed the rows down significantly but this file contains all of the columns.
The format of my data files will be the same. All of the columns will have a header in the first row, unit in the 2nd row, and numeric data in the remainder of the rows. The only exception will be the very last column in which contains date/time info in the following format YYYY-MM-DD HH:MM:SS.FFFF
If you can help draw something up to import this format I would greatly appreciate it. And not sure if this is possible, but often times the column count may vary, could have less columns or more, but the very last column will always have this date/time format.
Thanks for your help!
04-11-2022 02:30 AM
Hello MotoDude831,
I have attached a DataPlugin for this type of CSV files and the VBS code for it.
You can install the DataPlugin by double-click the URI-file.
Greetings
Walter
04-11-2022 10:25 AM
Walter,
This worked flawlessly. Thanks for your time and helping out with this.
MotoDude831
04-28-2022 10:06 AM
Do you know where I could find a plugin that would import xls files where the data points are in columns vs rows?
04-29-2022 03:23 AM
Hi Bob_engine,
The DataPlugin wizard supports only column wise stored data. So you need to create is by your own. Here is an example which fits with you example file.
Greetings
Walter
05-24-2022 01:09 PM
Hello Walter,
I'm back with another related question. How do you save/create the .uri files from a vb script. I've had no luck searching for this in the help resources in DIAdem.
05-25-2022 12:26 AM - edited 05-25-2022 12:45 AM
Hello MotoDude831,
Creating a URI file is the last step after developing and testing a DataPlugin. The URI file is created interactively.
If you would like to register a DataPlugin, you can use this command:
call Navigator.Settings.RegisterDataPlugin(...)
Greetings
Walter
This site uses cookies to offer you a better browsing experience. Learn more about our privacy statement and cookie policy.
