DIAdem
Copying Data from One Channel to a new Channel Overwrites Channel Name
I am writing a script which will take one data channel which has a repeating test sequence of 90 cycles. I'd like to separate the data into 90 separate channels, one for each test cycle.
I've created the new channels and copied the data, but when the data is copied into the new channel it overwrites the channel's name with the original channel name +1.
Is there a way of just copying the data, not the name as well?
dim i, j, n
i=1
j=900
n=001
Call DataBlClpCopy("[1]/P3_CL 1 PRESSURE [Bar]",i,j)
Call Data.Root.ChannelGroups(1).Channels.Add("Clutch 1 -" &" " & n,DataTypeFloat64,30)
Call DataBlClpPaste("[1]/Clutch 1 -" &" " & n,1,j)
(2,622 Views)
Accepted by topic author DTS_PBO
dim i, j, n
i=1
j=900
n=001
Dim newChnl, newChnlName
newChnlName = "Clutch 1 -" &" " & n
Call DataBlClpCopy("[1]/travel",i,j)
Set newChnl = Data.Root.ChannelGroups(1).Channels.Add(newChnlName,DataTypeFloat64, 30)
newChnl.Name = newChnlName
Make sure your destination index (where you have "30") is good.  I never use this parameter.
(2,586 Views)
Thanks, that worked perfectly!
(2,544 Views)
See the link below for examples of the DataBlCopy() command.
http://www.savvydiademsolutions.com/analysis.php?topic=NI-DIAdem-channel-data-manipulation-commands
(2,507 Views)
