DIAdem
Convert a group of numeric channels to waveform
Hey guys,
I'm working with about 150~ numeric channels where the names of channels will change occasionally...
I'm using a long command to convert all of them into waveform:
Call ChnConvertNumericToWaveform("[1]/Time (hh:mm:ss)", "'[2]/E1 Engine Speed'....149 other channels....)
Is there anyway to convert all channels in a group to waveform so I can avoid the script errors when the names of channels do change?
Thanks!
(1,568 Views)
Accepted by topic author Aroengines
Hi Aroengines,
you can use an ElementList to collect the channels to convert to waveforms. See my short example below.
dim i
dim channelList
set channelList = Data.CreateElementchannelList
for i = 2 to Data.Root.ChannelGroups(1).Channels.Count
  channelList.Add(Data.Root.ChannelGroups(1).Channels(i))
next
Call ChnConvertNumericToWaveform("[1]/Zeit", channelList, False, "WfXRelative")
Regards
Rainer
(1,486 Views)
