03-21-2018 02:05 PM
I am trying to write a Script to Plot a contour graph x,y,z when every component is a column of a Table except Z, is a matrix ( several Columns)
anyone help me with the script. I tried recording it but it does Not give me enough information. And there is no infos about contour matrix in the Manuel.
Thanks in Advance
03-22-2018 01:28 PM
If you have configured it the correct way you can open the config DIAlog in Report and press
CTR+Shift+C
This will put the vbs code into clipboard that you need to configure your plot like it is done currently.
Go to script and press
Ctrl+V
to insert the clipboard into the script editor.
In combination with teach in this shoudl give you enoug information to write your script.
