DIAdem
Reply
Conditional Formatting in MS Excel using Scipt
I have written a script which writes Channel Values to an Excel File.
After writng values to Excel, the below script executes which saves the file to a different path.
If I press 'YES' the file is saved or asks to overwrite. But If I click 'NO' an Option appears on Excel to save the file.I want to remove this Dialog in Excel .
Dim RawGroup,RawChannels,myExcelApp,j,myWorksheet,myRange,Excel
  Call GroupDefaultSet(28)
  Set myExcelApp = CreateObject("Excel.Application")
  myExcelApp.Visible = TRUE
  Set myWorksheet=myExcelApp.Workbooks.Open("FilePath
  Set myWorksheet = myExcelApp.Activesheet
  If MsgBox("Save Excel?", vbYesNo Or vbQuestion, "Bestätigen") = vbYes Then
     myWorksheet.Parent.Saved = True
    ' Call myExcelApp.ActiveSheet.Parent.SaveAs("FilePath")
    Call myWorksheet.SaveAs("SaveFilePath")
'      myExcelApp.close
      myExcelApp.Quit
    Else myWorksheet.Parent.Saved = False
'    myWorksheet.quit
'    myExcelApp.close
    myExcelApp.Quit
  End If
Next, I want to use conditional Formatting in Excel using DIAdem script function. Can it be done?
Have A Great Day
Himanshu Sharma
(260 Views)
Highlighted
Hey Himanshu,
           Consider adding this to your script:
 ExcelApp.DisplayAlerts=false
 ExcelApp.Close false
           It should remove any kind of prompts and save options. It works for me quite well.
          Also I think that you could do conditional formatting as well - depending on what you want to achieve. Check this link and see if it works out for you - it might give you some hints:
          https://stackoverflow.com/questions/13661965/conditional-formatting-using-excel-vba-code
Sincerely yours,
Denis
(143 Views)
Thanks Denis
(137 Views)
