DIAdem
Channel selection in DataPortal after script ends
Hi
At the beginning of my script, i select a channel in the data portal (structure view). At the end of the script, the channel should be selected again an it should be visible in the data portal.
When i run my script in debug mode, it works. But if I run it in "normal mode", I always end up at the top of the data portal with no channel selected.
Has anyone an idea how i can change this behavior?
Regards Werner
(2,817 Views)
   Hi Siipo,
Have you tried using the "record" scripting tool and compare with what you have done?
Have a nice day,
M-Junior
(2,783 Views)
Hi Siipo,
This code works on my DIAdem 2017:
dim oChn, oGroup
set oGroup = Data.Root.ChannelGroups(1)
set oChn   = oGroup.Channels(2)
call Portal.Structure.Selection.RemoveAll
if not Portal.Structure.IsExpanded(oGroup) then
  Portal.Structure.Expand(oGroup)
end if
call Portal.Structure.Selection.Add(oChn)
Greetings
Walter
(2,767 Views)
thanks for your code. I tried it and if i put just your code in a nem sheet, it works, but if i copy your code in to my script, i end with the target group open, but on the top of teh data portal and no channel selected. if i run it in debug mode, it works fine.
Code:
Option Explicit
autoabort = true
dim oChn, oGroup
T2 = "[1]" ' Kanalname
T1 = "free offset" ' Ogffset typ
R1 = 3  ' offset-Wert
T2 = Portal.Structure.Selection(1).GetReference(eRefTypeIndexName) ' [Gruppenindex]/Kanalname
If SudDlgShow("Dlg1",AutoActPath &"Offset_Dialog.SUD") = "IDOk" Then
Else
  Call MsgBoxDisp("DIAdem hat das Script abgebrochen.","MB_NOBUTTON","MsgTypeNote",,2)
  err.Raise -1
  err.Clear
End If
R4 = InStr(T2, "/")
R5 = Len(T2)
T3 = Mid(T2, (R4+1), R5)
R4 = InStr(T2, "[")
R5 = InStr(T2, "]")
'call MSGBOXdisp(""&R4&"//"&R5&"")
T4 = Mid(T2, (R4+1), (R5-R4-1))
R3 = Val(T4)
R2 = Data.Root.ChannelGroups(R3).Channels(T3).Properties("groupindex").Value
Call ChnOffset(""&T2&"",""&T2&"",R1,""&T1&"")
Call Portal.Structure.Selection.RemoveAll
set oGroup = Data.Root.ChannelGroups(R3)
set oChn   = oGroup.Channels(R2)
end if
(2,763 Views)
Accepted by topic author siipo
Hi siipo,
You're right. I've forgotten the (special) Portal refresh before my code.
call UIAutoRefreshSet(true)
call UIAutoRefreshSet(false)
set oGroup = Data.Root.ChannelGroups()
set oChn   = oGroup.Channels()
end if
By the way, you use the standard variables R1, R2, R3 ... as index. The R stands for real, but an index expects integer values. It would be better to use L1, L2, L3 ... for an index.
Greetings
Walter
(2,761 Views)
Now it works
thanks
(2,759 Views)
