04-27-2013 11:01 AM
I am using the following fuction to create and append data to a channel group:
Call ArrayToChannels(array, array_names,False, False)
The data appends to each channel correctly. However, once the channel is appended with the new data, the channel properties are NOT updated. Specifically, the channel max/min properties are not correct if the appended data would have changed one of those values. Looking at the data channel shows the values are outside of the min/max property values of the channel. This is problematic. Is there a way to make the channel properties refresh?
Thanks.
04-29-2013 12:58 AM
Update a single channel:
Call ChnCharacter("[3]/Res_Noise_1")
or all of them
Call ChnCharacterAll()
you can also find it in the context menue if you right klick on a channel in portal.
