DIAdem
Changing REPORT sheet in a Script
Is there any way to change the current sheet in REPORT, using a script?
I have 9 sheets in REPORT, each with different charts on them and am trying to update x-axis minimum and maximum values for all 9 sheets. This is part of an automated data-reporting process.
I am confused, because if I record the process of changing a parameter on sheet 1, and then on sheet 2, it applies the changes, sequentially, to only sheet 1. There is nothing in the script to tell DIAdem to switch the current sheet.
Any help would be greatly appreciated.
(6,192 Views)
Accepted by topic author RyanAsensio
Try changing the variable "GraphSheetCurrNo", it's the active sheet.
(6,170 Views)
Yes this works. Thanks! Also, GrpahSheetRefSet.
(6,164 Views)
Hi All,
For DIAdem versions 2012 and beyond, you have the option to address the REPORT panel with a new "Report" object, so changing the active REPORT sheet to the 5th one would look like this:
Call Report.Sheets(5).Activate
Brad Turpin
DIAdem Product Support Engineer
(6,118 Views)
