DIAdem
Change name of channelgroup to its actual filename
I want to change the name of a channelgroup to the actual filename of the tdms/data file.
Once data is loaded into Diadem, the root will be named as the filename of the tdms file and the channelgroups will be named the same name as the tabs in the tdms file.
Since I want to load several tdms files into one root and I want to change the name of the channelgroups to distinguish them apart.
Not just adding additonal text I want to change it to the filename of the tdms file itself.
So far I know this
'Change Channelgroup 1 name to Test 1.
Data.Root.ChannelGroups(1).Name = "Test 1"
'Change Channelgroup 1 name to its root name.
Data.Root.ChannelGroups(1).Name = Data.Root.Name
I cant find any filename or filepath.
/Nilfheim
Message 1 of 12
(3,450 Views)
Hi Nilfheim,
This can be done different ways, so I will give you the way I would do it. (Others can post theirs if they like!)
1) To get the file name to show up in a property (even when are loading multiple files
   Need to make a setting in   Settings |  Navigator |  and then look at the loading  Behavior Tab.
   Configure Property inheritance level to "Move to Loaded  level"  This will make is so that when  a file is loaded into portal it will copy all Root properties to the Group level with the "root" descriptors.  Then when you load multiple files you can always take  a look at the property and file out what file it came from.
2)  To read this file name or Change the group name.
Option Explicit 'Forces the explicit declaration of all the variables in a script.
dim oGrp: set oGrp = data.Root.ChannelGroups("Name of Group")
dim sFilename
sFilename = oGrp.Properties("root~name").Value
oGrp.Name = sFilename
Note: The group or channel names should not have "/" or "\" characters in them.  These mess with the group/channel separator that DIAdem users.  Should also make sure that clean up the group name some.   Screwy characters can cause problems.
3)  To iterate over all group
dim oGrp
dim oGrps : set oGrps = data.GetChannelGroups("*")
for each oGrp in oGrps
logfilewrite oGrp.Name
next
Paul
 Viviota.com
Message 2 of 12
(3,404 Views)
Thank you Pesmith8,
This question wasn't in the initial statement,
If I would just want to rename specific channelgroups like 1,3,5,7 and let the others keep their name.
It should be a combination of a for loop but since we are using 'for each' with object its making me confused.
How should i combine it?
Just a note on step 3 for others.
I just added it so it would actually change the name instead of just writing the names in the log.
dim oGrp
dim sFilename
next
/Niflheim
Message 3 of 12
(3,382 Views)
/Niflheim,
Try this out
You can add as many if statements as need to the group rename
dim iGroups: iGroups = data.Root.ChannelGroups.Count
dim i,x,y,z
for i = 1 to iGroups
if data.Root.ChannelGroups.Item(i).Name = "1" then
data.Root.ChannelGroups.Item(i).Name = "NewName"
end if
next
logfilewrite iGroups
Paul
Message 4 of 12
(3,375 Views)
Hi Nilfheim,
If you are looking for file name or file path, please have a look at the channel properties:
If you drag & drop a property into the script editor you get the syntax.
Greetings
Walter
Message 5 of 12
(3,369 Views)
@Pesmith8
Thank you, however I think I stated my question wrong so let me rephrase my question.
I want to rename every other channelgroup,  like number 1,3,5....
The names of the channelgroups will be random and not specific stated 1,3, 5..., could be random dates etc
It shall also be named to the filename as before.
I have tried myself but I cannot get it to work.
'-------------Count the groups
dim i
'-------------Step through every other group
For i = 1 To iGroups Step 2
dim oGrp
dim oGrps : set oGrps = data.GetChannelGroups(i)
'-------------Rename to root name
    dim sFilename
next
next
How do I go through all the groups or each other and rename them to root?
To implement "every other" channelgroup, is it better to use a for loop with step 2 or comparing like with modulus, ie mod?
In my code Im very unsure about this
In your previous example you used astrix which I presume means all channels.
@Walter_Rick
Thank you, it's good to know.
The change of settings that Pesmith8 noted was essential for this to be solved.
Thank you, you save me a lot of time.
Niflheim
Message 6 of 12
(3,361 Views)
Accepted by Niflheim
Hello Nilfheim,
A for loop with STEP is faster than modulo.
In general this loop should work:
dim iLoop, iMaxGroup, oGroups, oCurrGroup
'----- option one
set oGroups = Data.Root.ChannelGroups
iMaxGroup = oGroups.Count
for iLoop = 1 to iMaxGroup step 2
  set oCurrGroup = oGroups(iLoop)
  msgbox oCurrGroup.Name
  oCurrGroup.Name = "New name"
next
If you want skipping the first group, then start the for loop with 2.
If you want running over all groups delete the STEP parameter.
Keep in mind that group names and channel names (within the group) must be unique. Otherwise it will be automatically up-counted.
Greetings
Walter
Message 7 of 12
(3,354 Views)
Thank you Walter that worked.
For future references: The final version I used.
'-------------Set all groups
'-------------Rename current group to root name oCurrGroup.Name = oCurrGroup.Properties("root~name").Value next
Thank you both Paul and Walter.
/Niflheim
Message 8 of 12
(3,348 Views)
Just a small thing.
Performance is most of the time important. Also important is to know that in scripts each “.” and each indexing (especial string indexing like “root~name”) cost a bit time. In loops this can result in significant time consuming. (This is more a general information, if you have just a small number of iterations, you won’t see any difference.)
So, you can modify your script like this:
dim iLoop, iMaxGroup, oGroups, oCurrGroup, sRootName
sRootName = Data.Root.Name
  oCurrGroup.Name = sRootName
next
Also time consuming is the set command. If you only modify the group name you can delete this command line and use this assignment
oGroups(iLoop).Name = sRootName
If you have more actions with the group, the set command makes sense.
Greetings
Walter
Message 9 of 12
(3,340 Views)
Good to know.
However, your example just sets the channelgroups to the main root, I want it to be set to each root of their own.
In order to do that I had to change the loading behaviour according to what Paul noted.
Then I guess these custom properties for each channelgroup are created when loaded:
Data.Root.ChannelGroups(7).Properties("root~author").Value
Data.Root.ChannelGroups(7).Properties("root~datetime").Value
Data.Root.ChannelGroups(7).Properties("root~description").Value
Data.Root.ChannelGroups(7).Properties("root~name").Value
Data.Root.ChannelGroups(7).Properties("root~title").Value
I still don't grasp exacly how you obtain the root name of that specific group.
Best
/Niflheim
Message 10 of 12
(3,329 Views)
