Benchtop Measurement and Test
High-Performance Test
Systems Engineering Software
08-02-2018 12:03 PM
Hello!
I want to change a global variable when I push a button when "Start Display" it's running. I don't want to run script after or before measurement.
Can anybody help me?
Solved! Go to Solution.
08-03-2018 02:33 AM
There are some global variabes that you can use like R1 to to R32. In DAC there is a block "Save in Variables" in the "System" group:
http://zone.ni.com/reference/en-XX/help/370858N-01/dlgdacsv/dac_dlg_system/dlgvari_dialog/
You can use this block to save values in variables. See attach block diagramm.
Or you can use the "script driver". (Can run a script from a DAC?)
Hope this helps
Winfried
Thanks!
We'll be in touch soon!
