DIAdem
Can I add two properties and make it one property?
Hey guys!
I was wondering if I could add two properties of a channel to make one property.
For example, let's say the two properties are date and time - Aug. 17th and 1:00 pm.
I want to put them together to make a property called "blah" - Aug. 17th at 1:00 pm.
If possible I want to do this in script... any help?
Thanks in advance!
(2,292 Views)
Hi kmyan9,
You can read those two properties with a VBScript, do the math in VBScript, then save the result back to a property with VBScript.  It would be better to load those two properties as just one property, though.  What type of file is this?  Did you write the DataPlugin that is reading it?
Can you send a data file that has these two properties in it?  The exact VBScript code will depend on how those properties were saved.
Brad Turpin
DIAdem Product Support Engineer
(2,252 Views)
