DIAdem
Autosequence Extension-association for ASCII-Import (gfsascii.dll).
Highlighted
Attached file describe the problem AND the solution. There is however some things you could change to help other customers to avoid the problem I had. See Attachment !
(1,585 Views)
Hi Henrik
Thank you for your information. You are right in DIAdem we have several commands to import different file formats like DAT, Excel, Ascii, etc.. The reason for this is historical that means to be compatible with older versions, to be open for custom developments, to have restrictions of the existing data-management, to have an easy and flexible command interface.
One of our goals for DIAdem 9 was to have a unified data access. Therefore we developed a complete new data-management. And in the future we will have one command for importing values: DATAFILEIMPORT. And that?s the command which is recorded if you activate the script learning mode.
We think that this is a big advantage for the future.
Greetings
Walter
(1,585 Views)
