03-12-2019 05:48 AM
Dear All,
I have an issue with generating time channel automatically. I have data base of 4500-time channels divided into 750 groups. Each group contains channels with different length. Is there a possibility to create time channel for each group with VBA script?
03-13-2019 01:58 AM
Hi KrzyFul2,
Yes, it is possible to create a time channel in DIAdem. The script command for this is ChnGenTime. But if you need a more detaild answer, it would be helpful getting to know more content about what the time parameters are.
Greetings
Walter
03-19-2019 09:22 AM
Walter, thank you for the response.
I attached all the details in the .docx file. I'd deeply appreciate your assistance on this.
BR,
Krzysztof
03-19-2019 10:13 AM
Hi Krzysztof,
For DIAdem it doesn’t matter how many values a channel contains. But how do you know the parameters for the time channel? The function to generate a channel is ChnLinGen.
Extracting a part of a channel is possible. The question is how to know where to start and where to end this cut and how to automate this via algorithm (like if the amplitude is higher then x, this is the starting point, etc.).
I have a question in addition, is this a job you must do frequently – with similar a number of groups and channels?
And a last hint, DIAdem 2012 is about 7 years old and only as 32-bit version available. Current DIAdem versions are 64-bit and much faster and optimized. So, it can take more time to do this calculation in 2012 than in DIAdem 2018.
Greetings
Walter
03-19-2019 11:08 AM
You can try this starter script to loop through all channel groups and create a time channel (in seconds) for each channel as well as generate peak amplitude and frequency channels for each. You would have to change the sampling frequency at the top to the sampling frequency you used to collect the data. It works for DIAdem 2017 so I hope it matches 2012.
Option Explicit 'Forces the explicit declaration of all the variables in a script. ' ASSUMING ALL GROUPS WITH CHANNELS ARE LOADED INTO THE DATA PORTAL DIM SAMPLING_FQ_HZ: SAMPLING_FQ_HZ = 1000 ' DECLARE SAMPLING FREQUENCY ' Mark all the original channels Dim aGroup, aChnl, startTime, endTime For Each aGRoup In Data.Root.ChannelGroups For Each aChnl In aGroup.Channels Call aChnl.Properties.Add("To_Process", "Yes", DataTypeString) Next Next ' Loop through all groups and through all channels in each group to process For Each aGRoup In Data.Root.ChannelGroups Call aGroup.Activate() For Each aChnl In aGroup.Channels If aChnl.Properties.Exists("To_Process") Then startTime = 0 endTime = (aChnl.Size / SAMPLING_FQ_HZ) Call ChnLinGen("/" & aChnl.Name & " - Time", startTime, endTime, aChnl.Size, "") FFTIndexChn = 0 FFTIntervUser = "NumberStartOverl" FFTIntervPara(1) = 1 FFTIntervPara(2) = aChnl.Size FFTIntervPara(3) = 1 FFTIntervOverl = 0 FFTNoV = 0 FFTWndFct = "Rectangle" FFTWndPara = 10 FFTWndChn = "/" & aChnl.Name FFTWndCorrectTyp = "No" FFTAverageType = "No" FFTAmplFirst = "Amplitude" FFTAmpl = 1 FFTAmplType = "Ampl.Peak" FFTCalc = 0 FFTAmplExt = "No" FFTPhase = 0 FFTCepstrum = 0 Call ChnFFT1("/" & aChnl.Name & " - Time","/" & aChnl.Name) End If Next Next
03-20-2019 02:41 AM
Thank you both for help!
a script which was prepared by gsklyr works perfectly fine!
One last thing is Extracting a part of a channel. I'd like to cut this part of the signal in which amplitude exceeds 5% of the maximum value. So if I have 100 mm/s^2 then I'd like to extract the part in which amplitude is higher than 5 mm/s^2. Could you help me with that?
Walter, answering your question, yes I must frequently work with a similar number of groups and channels.
03-20-2019 07:57 AM
You can try this script code:
dim dLimit, iStartPos, iStopPos R1 = Data.Root.ChannelGroups(1).Channels("Signal").Properties("maximum").Value * 0.05 iStartPos = find("ch(""Signal"") > R1") iStopPos = FindReverse("ch(""Signal"") > R1" ) msgbox iStartPos &" - "& iStopPos call DataBlDel("Signal",1, iStartPos) Data.Root.ChannelGroups(1).Channels("Signal").Properties("length").Value = iStopPos - iStartPos
Greetings
Walter
03-20-2019 08:04 AM
Dear Walter, thank you for your response.
It works, but only for one channel. The signal in the second group stayed without any changes.
03-20-2019 08:36 AM
You can integrate it in first for loop of gsklyr's script like:
dim dLimit, iStartPos, iStopPos For Each aGRoup In Data.Root.ChannelGroups For Each aChnl In aGroup.Channels R1 = aChnl.Properties("maximum").Value * 0.05 iStartPos = find("ch(" & aChnl.GetReference(ExtendChnName) & ") > R1") iStopPos = FindReverse("ch(" & aChnl.GetReference(ExtendChnName) & ") > R1" ) call DataBlDel(aChnl.GetReference(ExtendChnName), 1, iStartPos) aChnl.Properties("length").Value = iStopPos - iStartPos Call aChnl.Properties.Add("To_Process", "Yes", DataTypeString) Next Next
Greetings
Walter
03-22-2019 09:22 AM
Dear Walter,
thank you for your response. Unfortunately, this script doesn't work.
Please find details in attachment. I am considering one more issue. Namely signal has contained values oscillating around 0 (seismic signal). So code "R1 = aChnl.Properties("maximum").Value * 0.05" could be inappropriate, cause maximum modulus value should be taken into account. Am I right?
