Autoactpath is a variable that points to the directory where your script is. If you have a menu item that displays the autoactpath without a script, you will get the path to the temporary folder. In any other case, you will get the directory of your script. I am attaching an example that creates 3 menu items. Two of them point to scripts that display the autoactpath. The last item doesn't call a script, instead it directly shows the autoactpath (here, it should point to the temp folder). The main script is called easy menu adder.vbs.
Best Regards,
Alejandro del Castillo
Application Engineer (NI)
