DIAdem
Assigning channel value to variable
tl;dr: how to put a particular channel value to a variable?
I have a channel with several numbers which I need to use as variables (they are indexes I need to point band cursor at), all I need is to grab a value from channel and assign it to a variable. I tried it simple, I tried it complicated, ChannelsToArray doesn't seem to help either (got type mismatch).
It should be really simple, shouldn't it?
(2,798 Views)
Accepted by topic author Adalbertus
dim chO : set chO = Data.Root.ChannelGroups(1).Channels("Time")
dim i : for i = 1 to chO.Size
  dim chVal : chVal = chO.values(i)
  MsgLineDisp chVal
Next
The channel object has a "values" attached to it.
(2,783 Views)
Well, now I am not sure what I did wrong, cause among others I also tried
Dim a
a = cX1Chn.Values(3)
msgbox(a)
I guess something else was wrong and I just falsely took it as bad syntax, anyway thanks.
(2,778 Views)
