In DIAdem 9 you can specify whether to use Unicode or Ascii in the new commands for text handling:
Function: TextFileOpen(Argument1,Argument2)
Argument1 Text with path, name, and extension of the text file.
Argument2 Attribute which opens the file. You can connect logically various attributes. (eg.
TfANSI Specifies that DIAdem codes a text file in ANSI or
TfUNICODE Specifies that DIAdem codes a text file in UNICODE.
I hope this will help you
Greetings
Walter Rick
