07-10-2007 10:55 PM
07-11-2007 03:21 AM
07-11-2007 01:34 PM
Thanks for the reponse. My comment about reading german was that their were books referenced in the forum that were written in german. I don't know if they were traslated, or if they are NI guides, or third party books. We have decnt thrid party and NI sponsored set of LABview (g-language) reference documents that have the complete syntax and command words. I read a few forum responses with examples and could quite follow some of the commands without the references. There appears to be a strong robust command in-line (scripting) capability.
Also, this morning we had upgraded to 10.1 and two things happened: 1.) 10.0 wasn't remioved/upgraded so it exists in its native form. there appeared to be some bugs with errors using the report writing features such as axis ticks. i then went to 10.1 and those errors were correted, but then found out the syntax had changed to aither AUT as original to VBS which I suppose really adds extra capability using visual basic formated commands. took me a while to know the change. then I also needed to download SP-1 already from the NI site.
I know this is relatively new (a couple of years for NI, but the documentation is quite thin as compared to the availability of Labview and and LABWindows CVI literature to cover in depth usage and code commands/syntax..
I'll try your scripting online idea in the mean time. I'll also look to see how the courses can be fit into our schedules.
regards,
Bill
11-29-2007 06:21 AM
I am new to DIAdem and have version 10.2. Unfortunately I am not comfortable in German and I have a German version. Kindly let me know where from I can download the English version of 'Getting Started' guide for DIAdem 10.2.
Thanks in advance,
With warm regards,
Saurav
11-29-2007 09:48 AM
Hi Bill,
I'm confused by your statements regarding the scripting change from DIAdem 10.0 to DIAdem 10.1. Prior to DIAdem 8.0 the automation language in DIAdem was indeed the AUT language, a proprietary, pascal-similar language that DIAdem invented. It was very slow and used all global variables and was thankfully retired back in something like 2001. But the AUT syntax still lingered in a few places, most notably in the Calculator and in the @ expressions, such as @ChnName(CCN)@, that you can embed in REPORT objects. As of DIAdem 10.1 both the Calculator and the REPORT expressions (now @@ expressions) switched over to using VBScript syntax. So as of DIAdem 10.1 the only places where AUT syntax still lingers is when you address DIAdem from an external compiler using one of DIAdem's two ActiveX servers, or when you start DIAdem with DOS extensions (say from a Windows shortcut) to start DIAdem with a specific personality.
Brad Turpin
DIAdem Product Support Engineer
11-29-2007 09:59 AM
Thanks, Brad for the document!
With warm regards,
Saurav
11-29-2007 10:30 AM
Bill, Saurav,
Here is another ducoment that you might find interesting and useful for your work:
http://zone.ni.com/devzone/cda/epd/p/id/5393
This document is being expanded over time, so check back to see if there is an updated version after a while.
Some more DIAdem documents are here:
http://digital.ni.com/manuals.nsf/websearch/1AEB6B0D74573E57862570D90071F55B
http://www.ni.com/support/diasupp.htm
To get access to an English version of the DIAdem software, please download from this link:
http://forums.ni.com/ni/board/message?board.id=60&thread.id=7399
You can use the English version of DIAdem with your license key instead of the German version.
Let us know if you have any additional questions,
Otmar
11-30-2007 04:10 AM
Dear Otmar,
Thanks for your help. Could you please let me know some books in English on DIAdem? I am a beginner to DIAdem and interested in knowing in detail about scripting in DIAdem.
With warm regards,
Saurav
12-03-2007 10:02 AM
