DIAdem
Announcing DIAdem 2020 SP1
DIAdem 2020 SP1 is out now and available for download.
The 2020 SP1 release of DIAdem features Real Drive Emission test analysis and compliance, NMEA2000 communications protocol support, new Drag & Drop function for the VIEW panel, and many other usability features!
Key features include:
General
  • The DIAdem icon was adapted to the new NI design and the REPORT template design was modernized.
  • The interface for Python DataPlugins has been extended. You can now check within the DataPlugin whether the file format is suitable for the DataPlugin. You can also specify whether the DataPlugin should only index a file or whether it should also be possible to load this file. If the Python code contains errors, the DataPlugin reports them to the user interface.
DIAdem NAVIGATOR, DataFinder, Data Portal
  • You can create calculation channels by executing mathematical operations on the channels of an existing channel group using a simple formula, or by using a calculation from the calculation manager. In a formula you can use channels, constants, numbers, and variables. To execute mathematical operations on them, you can use the basic arithmetic operations and all functions displayed in the dialog interface. If the functions in the formula channel are not sufficient to complete your task, create a calculation from the formula in the Calculation Manager and edit it there.
  • You can also use channel names containing DIAdem or VBS names in the formula of formula channels if you enter them as CH("Channel Name"). If channel names contain special characters, DIAdem inserts them into the formula with the expression CH("channel name").
  • For formula channels, you can specify a unit for the result. If you use quantity-based calculation, DIAdem checks whether the program can also execute calculations with the associated physical quantities.
  • DIAdem includes DataPlugins that allow you to load Real Drive Emissions (RDE) data according to EU regulations and save RDE analysis results.
  • In the Bus Log Converter the ID mode NMEA2000 has been added in the database configuration. This mode is standard for serial data networking of electronic devices in naval vessels and is also frequently used by GPS hardware on commercial vehicles or agricultural machinery. For more information, visit the National Marine Electronics Association website.
DIAdem VIEW
  • A new Drag & Drop function for the VIEW panel makes it easier to move VIEW areas.
DIAdem ANALYSIS
  • The new RDE (Real Drive Emissions) functions allow you to evaluate the measured emissions from motor vehicles while driving on public roads, according to European standards. The calculations are based on the "COMMISSION REGULATION (EU) 2018/1832" of November 5, 2018.
For additional information view the ReadMe.
Message 1 of 1
(1,681 Views)
