11-07-2018 08:31 AM
Hi all!
I’m new to the Diadem environment, and I have faced an issue.
I have a data acquisition software that was built in LabVIEW, the data is being saved from the software in TDMS files,
The data waveform must be organized in the following hierarchy:
The way we have thought to do this so far is to creates the TDMS files in the following manner:
A file for every type of data acquired (for example: a file for voltage, current, etc.)
Inside the file there is a group for each “event” recorded, those events are number in an indexed manner (i.e. Event 1, Event 2 etc.…)
The group contains a waveform for each UUT device recorded in the event (Device 1, Device 2, etc...)
Attached to this are two files for example
When I do make the files in this manner I face the following issue:
When I open the first of these files in Diadem everything is fine, and the file is indexed correctly (see photo below)
When I try to add a second file to the Data portal, instead of showing the file separately (using the group name inside the file) Diadem adds the new file to the same data source and continue to index of the groups from the end of the previous files (see photo)
It is important to note that the example files are small, but in real applications I can have many UUT’s and many events, storing data from serval parameters. therefore, this issue makes data analysis very tough.
My questions:
Solved! Go to Solution.
11-07-2018 09:35 AM
What you can do is changing the separator.
Using e.g.
UniqueNameSep = "Semicolon"
or the settings dialog which will result in a different looading behavior.
Be aware that the amount of groups and channels has a limit.
11-07-2018 11:29 AM
Try these to ideas:
1) Make the File level properties to be copied to the Group level.
DIAdem settings, Navigator| Loading behavior, and the select property inheritance level to Move to loaded Level. Now you can see in the props for each loaded group what file the group came from.
2) Write a small script that when each file is loaded, Will add a prefix to group name that will allow you to know what file it came from. (something unique.)
Maybe something like this script
Option Explicit 'Forces the explicit declaration of all the variables in a script.
dim oGrps: set oGrps = Data.root.ChannelGroups
dim oGrp
dim sPropvalue: spropvalue = oGrp.Properties("Property name that has unique name").Value
dim sOldGroupName
for each oGrp in oGrps
sOldGroupName = oGrp.Name
if left(oGrp.Name,5) = "Event" then
oGrp.Name = sPropValue & "_" & sOldGroupName
end if
next
Now you will have in portal something that will let you know what file it came from as a part of the group name, as well as properties for each group that will let you know what file it came from.
Paul
11-08-2018 08:54 AM
Hi!
this work wonderfully!
now i can analyse the data in a organized way!
(see photo)
thanks a lot 🙂
