DIAdem
Add delimiters in "AddCalculationChannel" formula
I am trying to merge the content of three channels into a new one by using  "AddCalculationChannel" method.
It is working fine with the below formula:
Data.Root.ChannelGroups(i).Channels.AddCalculationChannel("Result", "=Status & Cycle & Temp")
...and my data:
But I need a delimiter (on the Result channel) between the content of the three channels like that: "OK-1-70"
The result "OK170" is not so convenient for me.
I couldn't find any formula to add a delimiter btw the contents, any string constant in the formula results in a 0 output.
(2,230 Views)
Hi SorinP,
This calculation channel is designed to support calculations with channels. Adding a single character does not work. But you can create a text channel which contains the delimiter character and add this channel to the formula.
Greetings
Walter
(2,178 Views)
Thank you Walter, I will create a single delimiter channel and use it wherever I need.
Sorin
(2,175 Views)
