this error appears quite randomly when i am try to average of a channel. When this appears i just close Diadem and it works afterwards. Do you have any idea why is that?
Thank you for posting this question. I would like to check up on this post since no one in the community has gotten back to you yet.
Could you possibly the part of your script that is dealing with this channel? Since the code usually works I doubt that this is an issue with your code. Have you tried running the code on another machine? If so, it is possible that your computer's RAM and CPU sometimes reach critically high levels.
Yes, i did try to run it on other machine and still i get the error 1 out 10 times. Well it could be the RAM and CPU is there a way how to prevent it from happennig ?
