DIAdem
Access to a channel value from a MF4 file
I'm working with DIAdem 2017.
I load a mf4 datafile in the portal with a drag and drop method. The data plugin I used is the one from the website 1.3.0.7307.
When the channel appears in the Data portal it has a yellow A? what does this letter mean?
When I try to read the first value of the channel A with the both following syntax:
- Msgbox Data.Root.ChannelGroups(1).Channels("ChannelA").Values(1)
- Msgbox Data.GetChannel("Group_1/ChannelA").Values(1),
the msgbox is empty in both cases.
I do not understand with this syntax is not working because I used to use it for mdf3 file without any issue.
Thanks for your help.
Xavier
(207 Views)
I forgot to put a print screen of the data portal in my previous message. See attachment.
(205 Views)
(205 Views)
Hey Xavrocg,
I tried with Test1.MF4 (in the .zip attached) and used
Dim oMyChn
Set oMyChn = Data.GetChannel("[1]/[2]")
Call MsgBoxDisp (oMyChn.Values(1))
For this I get the correct output in my message box.
Are you able to provide a file to test with? Or try with the Test1.Mf4 or the above code to see if you can get this working?
Let us know how you get on,
Rebecca
(137 Views)
