Hi Charlie92,
Let me give a more detailed description of what is happening here. First of all, as Walter says, it's always a good idea to keep SQL column names as simple as possible. Microsoft can get around the traditional difficulties you encounter with fancy column names by keeping everything "in house" between say Excel and Access, but as soon as you start to use actual SQL commands from an external application, you run into problems. You have several columns in your database with either a space, an "&", a "�" or a "/" symbol in them-- all of these are problematic when creating and using SQL queries. I have renamed these columns and seen an immediate improvement in the values imported:
"chiller no"..............."chiller_no"
"downloaded data".........."downloaded_data"
"Date&Time"................"Date_Time"
"T_retn F�"................"T_retn_F"
"T_supl F�"................"T_supl_F"
"T_evap F�"................"T_evap_F"
"T_cin F�"................."T_cin_F"
"T_cout F�"................"T_cout_F"
"T_cond F�"................"T_cond_F"
"T_suct F�"................"T_suct_F"
"T_liq F�"................."T_liq_F"
"T_dis F�"................."T_dis_F"
"T_comp F�"................"T_comp_F"
"o/h"......................"o_h"
"T_retn C�"................"T_retn_C"
"T_supl C�"................"T_supl_C"
"T_evap C�"................"T_evap_C"
"T_cin C�"................."T_cin_C"
"T_cout C�"................"T_cout_C"
"T_cond C�"................"T_cond_C"
"T_suct C�"................"T_suct_C"
"T_liq C�"................"T_liq_C"
"T_dis C�"................"T_dis_C"
"T_comp C�"................"T_comp_C"
Secondly, the values in the "I" column appear to be different, but that is only because of the displayed rounding in that column-- if you make the column slightly wider you will see the values match.
I have attached an edited version of your database with the new column names described above.
Brad Turpin
DIAdem Product Support Engineer
