DIAdem Idea Exchange
JoshRew
Freeze Frame
Status: Completed
Completed with DIAdem 2014 (Context menu "Lock columns" to always see selected columns when scrolling.
I would like to request th ability to "Freeze" columns in a view table so they stay on the left-hand side of the table as you scroll to the right.
The channel names/properties sticking at the top works brilliantly, but if you want to have a timestamp channel (or Timestamp, Speed, and Torque channels) visible when you have a view table with many channels you have 3 options:
  1) Scroll back and forth a lot
  2) Add a new occurrance of the channel(s) into the table and move it(them) to the correct spot
  3) Have 2 tables side-by-side and vertically scroll them both together manually
I would suggest 2 interfaces to select the columns to freeze at the left hand side of the table:
  1) Right-Click menu called something like "Lock Column(s) at Left" or "Freeze Column(s) to Left" (Or just "Lock/Freeze Column(s)")
  2) On the "Display" interface, have a "Lock/Freeze Left" checkbox on the columns in the Name/Format table (you may also want to have a "Lock to Left First # Channels" checkbox for the All/All of a group channel table options)  This should probably automatically move the columns selected to the top of the list so they appear in the order they will display in the table, as well as allowing the user to rearrange the leftmost columns (if they lock/freeze multiple columns)
-Josh
1 Comment
dietfons
Status changed to: Completed
