A fairly common graph (for me anyway) is a Bar plot with positive vertical error bars drawn:
In Diadem 2010 and previously, it was possible to create such a graph by creating a Line plot with error bars, and then converting to a Bar plot- a little dodgy, but it worked. In Diadem 2011, this no longer works, and it is necessary to create two plots: one Bar plot and one blank Line plot with error bars.
My suggestion is that it would be much cleaner to allow the definition of error bars on a Bar plot directly - after all it is a single quantity. In fact, almost all of the other plot types could also benefit from being able to add error bars directly.
This would also help in being able to create Box plots - a process that is currently less than straight-forward.
Hello
Thank you for your request. R&D has read this suggestion and it will be included in feature planning discussions for future DIAdem versions.
Greetings
Walter
