DIAdem Idea Exchange
Bernd73
Edit group properties in the text data plugin assistant
Status: Completed
Released/Fixed with DIAdem 2015
Currently the data type of group properties is automatically set, when two colums are used, one for "Name" and one for "Value". (see picture, right side)
I recommend to enable the possibility to manually set the data type for every individual entry, regardless which column is chosen for Name and/or Value.Bild1.png
4 Comments
Brad_Turpin
Trusted Enthusiast
Hi Bern,
That's a great idea!  Of course, at some point you end up programming the ASCII DataPlugin from scratch yourself.  Let me know if you ever need help with that, that's one of my favorite tasks.
Brad Turpin
DIAdem Product Support Engineer
brad.turpin@ni.com
StefanR
NI Employee (retired)
Hi Bern,
please note, in the use case as described by you, the data type is determined auromatically and you see (in the wizard) the data type which would be chosen for this particular file.
For example, considering two files:
one has a line:          propname    0.01
the other has a line:  propname    blabla
The data type of property "propname" in the first file will be read as eR64, while in the second file the data type will be eString.
MarcusP
Status changed to: In Development
dietfons
Status changed to: Completed
