DIAdem Idea Exchange
JoshRew
Channel Table Inserts
Status: Declined
When dragging and dropping a channel into a View or Report table from the Data Portal, no matter where you release the channel, it's always appended to the end.  This can be frustrating if you have a large number of channels in the table, forcing you to rearrange the table after each channel is added.
I would like to propose the ability to drop channels in-between columns of the table, OR append channels on the end.
I would think that the area you drag the channel into would decide where it inserts:
  Between 2 channel headers (anywhere in the "Selected Channels" section or above) = Insert
  Anywhere on the "Channel Contents" section, row numbers, or blank area without channels = Append to end
Thanks!
-Josh
2 Comments
Walter_Rick
NI Employee (retired)
Status changed to: New
Hello JoshRew,
Thank you for your request. We understand your suggestion but given the age of this entry and the fact that just a few sponsors are supporting it, we have decided to decline this suggestion and prefer to develop more frequently requested features instead. We hope you understand this.
But if you open the tabel dialog you can select a row and insert there a new channel.
Greetings
Walter
Walter_Rick
Status changed to: Declined
