DIAdem Idea Exchange
JuliaDawkins
Allow VIEW area re-arranging by clicking/dragging
Status: Completed
Hi Julia,
This feature request is implemented in DIAdem 2020 SP1.
Greetings
Walter
Sometimes you want to move an area around, and the only way right now is to re-create an area which is quite inefficient.
13 Comments
Brad_Turpin
Trusted Enthusiast
Hi Julia,
I like this idea a lot.  How about this for a practical clarification of your suggestion-- what if when you dragged Area1 onto Area2, the locations of Area1 and Area2 were swapped?  That would make the implementation much more defined, because both the user and the DIAdem developer would always know where the area should be dragged to, and the overall layout of Areas wouldn't need to change.  Or are you envisioning a different "move" dynamic here?
Brad Turpin
DIadem Product Support Engineer
JuliaDawkins
Your clarification describes what I'd like perfectly!
CReese
It would also be nice if you could drag sheets to rearrange w/o the dialog box.
Brad_Turpin
Trusted Enthusiast
Hi CReese,
I totally agree that dragging sheets in VIEW or REPORT or SCRIPT to rearrange them directly would be awesome.  It's a very common feature in a lot of products and matches what most customer expect.
Brad Turpin
DIAdem Product Support Engineer
jtw131
In addition, the ability to "clone" an area by copy / paste would be very useful.
James_McN
I definately like this. Examples of similar behaviour would be in customizing group pages in ni community.  This may be a bit rich but just swapping would be good, but what if they are currently next to each other and you want them above/below instead.
James Mc
CLA and cRIO Fanatic
My writings on LabVIEW Development are at devs.wiresmithtech.com
dietfons
Walter_Rick
NI Employee (retired)
Status changed to: Under Consideration
Hello
Thank you for your request. R&D has read this suggestion and it will be included in feature planning discussions for future DIAdem versions. But because of the huge numbers of possible DIAdem extensions, we gave this request a very lower priority.
Greetings
Walter
Walter_Rick
Status changed to: In Development
This feature request is planned for DIAdem 2020 SP1
JuliaDawkins
Exciting, thanks!!
