DATA AHEAD toolkit support Documents
XLR8 Error Codes
Attached you will find the most recent list of custom error codes that can be generated by XLR8.
If you encounter an error from XLR8, make sure to read the short explanation and take a look at this document. If the problem persists, feel free to contact us via e-mail or in this forum.
Comments
Hooovahh
Proven Zealot Proven Zealot
Proven Zealot
on
Is there a error codes file that can be used so these error codes are included and recognized in LabVIEW?
https://www.ni.com/docs/en-US/bundle/labview/page/defining-custom-error-codes.html
Peter-daq.io
on
Hi Hooovahh,
the codes are stored internally, not in the lv-error format. Therefore, you do not need to deploy any files with the program. This file is just a tool to explain the errors you might encounter in more detail.
In future releases, XLR8 will use other error codes that are reserved by NI, so it won't interfere with any existing custom error codes.
Cheers
Peter
CLD | Alliance Partner | Web data storage and visualization | daq.io
Contributors
