SP7 is compatible with all LabVIEW versions starting with LabVIEW 2011.
Please have a look at the Quick Reference Guide and make sure that you configure your S7-1200 correctly. You need to allow the Put/Get protocoll and disable the optimazation on your DB you try to write or read.
DATA AHEAD
Kudos are welcome...
