DASYLab
time too fast in dasylab
I added a measurement time indicator in my layoutscreen in Dasylab but: time is running too fast. how can I fix this?
I am using "dasylab" in the timebase setting. Software: Dasylab 10,  windows Vista Business SP2 32bit
Hardware: Acer travelmate 5730, Centrino duo core T6570 2,1 Ghz, 2Gb internal memory, ICP CON modules: i-7561, m-7080,  m-7080, m-7017, m70182.
Kind regards,  Wouter
Message 1 of 8
(7,774 Views)
Dear Wouter,
What do you mean too fast?  Compared with what?
Also, would it be possible to see the worksheet?
Tom Rizzo
InSyS Corp.
www.insyscorp.com
Your DASYLab integrator
Message 2 of 8
(7,772 Views)
Dear Tom,
"What do you mean too fast?  Compared with what?"
Compared to realworld time seconds.
yep: I'll include three pictures:
Full screen, timing detail and settings of the Time base
Kind regards,
Wouter
Message 3 of 8
(7,767 Views)
What is the DASYLab time base set for?
Do you have any other time bases configured?
Measurement Computing (MCC) has free technical support. Visit www.mccdaq.com and click on the "Support" tab for all support options, including DASYLab.
Message 4 of 8
(7,763 Views)
Hi. Yes, I have anothe timebase:other timebase.PNG
And the DL measurement settings:timebase_Dasylab.PNG
Hope you can help.
Kind regards,
Wouter
Message 5 of 8
(7,737 Views)
Wouter,
When I look at the worksheet logic that you show:
Timebase (pulse per second) -> Action controlled Relay -> Counter
You label this as Min (Minute?). Shouldn't the Timebase be "Pulse per Minute"?
Message 6 of 8
(7,733 Views)
Hi Cj,
You are correct, originally I wanted it to display the measurement duration in minutes. But the minutes timer counted too fast (i am shure the timebase was set to pulse per minute).
To find the fault quicker I changed the timebase to seconds to get a feeling what was going on.
Kind regards,
Wouter
Message 7 of 8
(7,731 Views)
Wouter,
did you set the DASYLab timing and block size the same as the hardware ones?
Tom Rizzo
InSyS Corp.
www.insyscorp.com
Message 8 of 8
(7,724 Views)
