11-05-2009 10:25 AM
Hello CJ,
I want to genetate a mixed signal which contains a 10 seconds Square wave, and then 10 seconds Sine wave. This signal then send out to the analog output. Is there any simple way to do it? Thanks.
Alan
11-05-2009 11:19 AM
In DASYLab Pro, I would advise you to use the Sequence Generator module. It allows great control of a generated waveform.
However, you don't, so, here's the alternate
Setup the Generator module for two channels, one for the Square Wave, one for the Sine Wave. Connect to the Control/Signal Switch module, configured for time. Setup up the time duration for each channel.
