DASYLab
Delphin Expert Key 200 API + Dasylab v13 full = Error collecting values
That's good news about Delphin.
For DASYLab 2016 (V14), they will need an updated driver again. The changes to the software require that all extension dlls, like most drivers, be updated and recompiled/relinked with the updated toolkit.
CompactRio should work - install the NI software for it - Measurement and Automation World and the NI-DAQmx drivers. Set up one or more TASKS in MAX, test and save them. When you create the NI Analog Input, you will select the task that you created.
If you need to change the task, do it in MAX, and then use the DASYLab Measurement >>Hardware Settings>>NI to synchronize your worksheet with MAX.
Are you in the UK?
Measurement Computing (MCC) has free technical support. Visit www.mccdaq.com and click on the "Support" tab for all support options, including DASYLab.
Message 11 of 11
(1,163 Views)
