Hi YWTSC,
If you work off of the 'Bridge Continuous Input' example in DAQExpress located at: Examples>Code Samples>Data Acquisition>Analog Input>Bridge Continuous input, this should give you a good starting point.
Basically you need to change your sensor task from a Voltage task to a Bridge or Pressure task, see the screen shot below for what this would look like setup with a 9205.
Let me know if you have other questions.
Andrew B.
Application Engineer
National Instruments.
http://www.ni.com/support
