DAQExpress
DAQExpress, view multiple captured channels i graph after measuring
I am using DAQExpress 5.0 and are logging several channels.
When plotting the captured data after measuring I can only see one channel in each graph.
Is there a way to see multiple channels in a post graph?
(2,870 Views)
Hi Niklas,
I have set up a project to acquire multiple channels and after I click record I have double clicked on "Recording 1" rather than a specific channel to display all the data. Within that, if any channels aren't showing in the plot, but are along the bottom bar, I have right clicked on them and clicked Show Plot
Hope this helps! If it doesn't, can you post a screenshot of what you are seeing in DAQExpress? With that it will be easier to pinpoint what you need to change in the configuration to see multiple plots.
Alastair
(2,816 Views)
Hi Alastair,
I made a new try with multiple channels in DAQExpress and did a plot as you described.
Now it works!
Thanks for your help!
(2,795 Views)
