Counter/Timer
rpm measurement
I have a compact field point system. I would like it to count TTL pulses for an RPM measurrement. how can i measure pulse counting either using prescaler counter method or elseany other method,i need clarification that other than cfp configurung using MAX, is it possible to configure cfp-ctr-502 using labview itself
(3,537 Views)
I think you'll find the answer in the following dev-zone example:
http://sine.ni.com/apps/we/niepd_web_display.display_epd4?p_guid=B45EACE3EBA556A4E034080020E74861
It implements a frequency counter using the module you mention and I
successfully used this method.
Greetings, Jeffrey
"anu" <x@no.email> schreef in bericht news:199753@exchange.ni.com...
(3,529 Views)
