I would like to measure the resistance between 2 points using my PCI-6602 counter/timer card while using LabVIEW. The resistance values to be measured will vary between 10 ohms and 1000 ohms approximately.
I found three examples in LabVIEW example finder for measuring resistance but am not sure which one to use. Moreover, which pins of the PCI-6602 would be used for measuring the resistance?
Please advise me how I could use this PCI-6602 card for measuring resistance values and what the pin configuration would be.
Thank you,
Viktoriya.
