12-12-2006 02:39 AM
12-12-2006 06:35 AM
You're in luck. Because the M-series boards support digital change detection (since DAQmx 8.0), you can actually set up a digital input task that's sensitive to both rising and falling edges of both A and B. This in turn generates an internal "change detect pulse" signal which can be used as a sampling clock for other tasks such as Analog Input.
Here's a link to a posted example with more context found in the associated thread. I've used this technique to get samples on every quadrature edge too, so I can vouch for it.
-Kevin P.
12-12-2006 07:36 AM
Thanx!
spending some time on the threads... I happen to come across it -was wondering if this was the way to go. Maybe one last question, I've read abit about applying digital filtering to decrease jitter -does it hold true for the M-series? will it be needed -or is it a case of- if you need it use it...
Again, thanx for the advice!
12-12-2006 12:21 PM
Hmmm, not sure how to comment. When I think of "jitter", I think of an undesired variation in time intervals. I wouldn't think that the digital filtering features would be a very natural way to address jitter.
It may be a moot point though. Digital filtering can be configured for "PFI" pins on the M-series board, but those pins can't be used for correlated DIO -- only for software-timed static DIO.
I haven't found the need to use digital filtering in quite a while. Need or lack thereof pretty much depends on the type of sensor signals you have and the kind of electrical environment you're in.
-Kevin P.
