10-05-2019 05:01 AM
hello,
for counter output to drive a stepper motor which option is better.
1. to generate 1 pulse at a time in a while loop with a rate defined by ms delay vi
or
2. burst of pulses at once
if we use option 1 is it accurate to pulse time periods of all train of pulses
thanks
10-06-2019 11:24 PM
Option 1 would be software-timed, which means your while loop may not loop precisely at your designated speed so not recommended.
Option 2 would be the way to go since you will control the counter output with the onboard clock, so you can produce precise pulses at the correct timing.
10-07-2019 01:03 PM
so Burst means HW timed or we can use another specific way to implement HW timed loops. does ni cards have inherent clocks that we can use to achieve precise timing or delays without using Labview RT
10-07-2019 10:24 PM
Which hardware are you using? NI DAQ products have inherent clocks so you can output pulses from counters with precise timing. You don't need LabVIEW RT to do this.
http://www.ni.com/documentation/en/ni-daqmx/latest/mxcncpts/controlappcase4/
10-08-2019 09:17 PM
You seem to have created several threads on closely related questions. It'll be best if you can focus the conversation to one of them.
Over in this thread, I suggested that your 6229 card isn't a very good choice. Something from the X-series family (63xx) would be better.
-Kevin P
