04-26-2019 02:27 AM
I'm using the NI USB-6221 which has two counter to my knowledge. I need to output 6 PWM signals (same freuquency, but independent duty cycle) to control 6 external valves. Is that somehow possible or would I need a DAQ device with 6 counters?
Best thanks for any help/idea!
Solved! Go to Solution.
04-29-2019 01:02 PM
Assuming you need to vary the duty cycle as the program runs, you'll need 6 counters. In addition to the 2 you have on your USB-6221, you could add 4 more with an X-series board (which are available in USB form, unlike the dedicated counter/timer boards).
-Kevin P
04-30-2019 01:32 AM
Hi Kevin,
Thanks for your reply. You correctly assume that I need to vary the duty cycles during run time. I will consider your suggestion.
Best,
maxJack
