One way to do this would be to setup your counters to preform a frequency measurement. You should be able to find a shipping example that accomplishes this. If you know the freqeuency and duty cycle of the sqaure wave from your motor, you can calculate speed.
My power drill DC motor is part of a setup in an experiment. As the voltage increases the RPM of the drill is NOT linear but changes in an UNCERTAIN way. Thus the voltage applied to the drill is not an indication of the RPM. To find the RPM, I need an external tachometer.
I have attached a file about my setup. I need to measure the RPM of the rotating disk with a tachometer. However I cannot afford one. I have build my own SIMPLE tachometer using a torchlight and a photoresistor diode. Can it work? How do I connect the photoresistor to my 6025E DAQ card? Which PINS? I have attached also the PIN sheet.Do you know where I can get a tachometer.vi.?
Try a little harder. Why don't you simply go to the search tab and enter frequency? From the browse tab, you have Hardware Input and Output>DAQ>Counters. From there, you'll need to know the type of counter on your daq board. Check your manual.
