Counter/Timer
counting falling edge on pci 6281
I have an analogue signal consisting of pulses of 5V (reference level 5V, pulses to 0V) which occur randomly.
I read this signal in using a pci 6281 NI card. This works fine.
Now I would like to count the number of pulses for a given time (e.g. number of falling edges). According to what I read in the manual it should be possible to configure the system such that one can start a counter (arm it) and then ask the counter from time to time what the current number of pulses is.
So the question is rather simple: what is the best configuration to do this? Should I use a different input (instead of analoge input)? Can I use the simple 'count events or time.vi' or should I use more advanced counter vi's?
Thanks for any suggestion.
(3,441 Views)
Dear Steven,
The best way to count events (falling or rising edge), it is to use the counter functionality. The device NI-6281 provides two counters.
That means
    for the Software: see the examples under. Find Examples -> Hardware Input and Ouput -> DAQmx -> Counter Measurements -> Count Digital Events
    for the Hardware: you need to connect you signal to the input ctr0/source
PS: Counter level is based on the TTL technologies
Best regards
Nick_CH
www.ni.com/gettingstarted
(3,410 Views)
