Counter/Timer
Writing to DAQmx Channel does not update phisical channel on DO card
Hello guys,
I have created a program to control a valve with PWM signal.
Here I create and run the task:
And here I change the pulse width:
I can see, that the Pulse Width property does update, but on the channel does not.
I also tried this, but its the same:
What am I doing wrong?
HW info: cDAQ 9172, NI-9474.
NI-9474 card is mounted on cDAQ slot 6.
Best Regards,
Jakob
(2,309 Views)
Accepted by topic author Jakob_Pin
This is a subtle one that comes up once in a while.  Here's one recent time.
Expand the property node down and *also* re-write your desired frequency value, even if it remains constant.   Writing freq is what causes the driver to use both new parameters.  Dunno why.  (Other recent experiments suggest that "low time" or "low ticks" have a similarly privileged behavior as compared to high time and high ticks.)
-Kevin P
CAUTION! New LabVIEW adopters -- it's too late for me, but you *can* save yourself. The new subscription policy for LabVIEW puts NI's hand in your wallet for the rest of your working life. Are you sure you're *that* dedicated to LabVIEW? (Summary of my reasons in this post, part of a voluminous thread of mostly complaints starting here).
(2,282 Views)
Thanks Kevin,
it works like a charm!
Best Regards,
Jakob
(2,273 Views)
