Counter/Timer
Wiring a SCB-68 to measure the frequency of a TTL pulse signal
Sorry if this is a basic question but could someone please help me and tell me how to wire up a SCB-68 connector block (connected to a AT-MIO-16 DAQ board) so that I can measure the frequency count of a series TTL pulses (signal from photon counting). At the moment I don't understand how the PFI1-9 connections are related to the GPCTR0/GPTR1 counter connections on the block and how they're all realted to the source,gate and out 1-5 connections on the DAQ board.
Ultimately I want to be able to put this measured frequency into a Labview program with a controllable gate period.
Thanks in advance
Nick
(3,385 Views)
If you go to MAX and then select help from the top menu you eventually get through the menus to NIDAQmx Help. There is a folder for Device Terminals, the M Series is not listed but they are almost the same as the E Series. I'm not familiar with that board, but since no one else answered this you can get the pins from the E Series 68 pin connection diagram.
Otherwise download the Help file for your board and it should be there.
Ed
(3,363 Views)
You might want to search the Knowledge Base on the NI's Support Pages for "Cable Mapping for a 68 Pin Connector to a 50 Pin Connector". This should take you to a link that will explain the mapping of a 50way to 68way cable and subsequent lines you are looking for ( reference sub link 68F50M), I guess you have SH6850 cable connected from the AT-MIO16 card to the SCB-68.
Please check out the information about the pin outs, that should help you work out which pins map to the counters, eg GPCTR0_source would be pin 37 on your SCB-68
Regards
Joe (NI)
(3,344 Views)
