01-08-2020 09:20 PM
I would like to output a continuous pulse signal with a voltage of 5V.
Currently on my oscilloscope I am only seeing approximately 2V.
My code in C++ goes like this:
DAQmxCreateCOPulseChanFreq(taskHandle0, "/Dev1/ctr0", "", DAQmx_Val_Hz, DAQmx_Val_High, initial_delay, signal_frequency, signal_dutyCycle)
Is there anyway to increase the output voltage from the counter?
Thank you!
01-09-2020 12:13 PM
Any chance your scope input impedance is set to 50 ohm instead of 1Mohm?
-AK2DM
