04-15-2009 04:12 PM - last edited on 02-26-2024 11:56 AM by migration-bot
I am trying to measure the frequency of a signal that I'm counting using the cFP-CTR-502. I can successfully count pulses but I what I really need to know is the RATE of counts (counts/s or the frequency). I have found some Labview programs that supposedly do this that I've downloaded from ni.com (link below). The concept makes sense of using a gate and output but the programming is crazy - at least the program in the link below is.
1. Is there an easier way to measure the frequency of counts?
2. Why will the program from the link below ( frequency_measurement__ctr_.vi ) not work on my system? I get an error everytime I run it. Could I be missing some VI's necessary for it to run? Or is it from another LabView version that is not compatible?
The entire error is: -32810 occured at FieldPoint initialization failed. Possible causes, 1. Missing or corrupt configuration file; 2. Failed to create call backs. : FP Open.vi
Link for program: http://sine.ni.com/devzone/cda/epd/p/id/4682
Thanks in advance for all your help and time!
Sam T
04-16-2009 10:15 AM
Sam,
Have you tried the example titled Frequency Measurement.vi that ships with LV?
