Counter/Timer
Route Signal in a 6601sending a 1 from PFI_0 to Gate0
I´ve a 6601 board and I want to send a "1" from a PFI_X to Gate_X, using the "Route Signal", not wiring. Is it possible?.Is there any example showing how to do it?
thanks a lot,
enzo
(2,735 Views)
Hello Pasqui,
This should be possible with a DAQmxConnectTerms() function in DAQmx, or a GPCTR_Change_Parameter() function in Traditional NI-DAQ. ND_Gate is the parameter that must changed with the latter function.
Let me know if you have any further questions.
Sean C.
(2,725 Views)
