Counter/Timer
Reading Angles From a Line Driver Quadrature Encoder
I currently have a Quadrature Encoder (Line Drive) and am trying to interface it with a PCI-6602 Counter/Timer Card. I have currently had no luck in correctly hooking it up and reading the angle. Past experience with Quadrature Encoder have all been open collector; I have been able to to successfully hook up an open collector encoder with the 6602.
Any help in hooking up the Line Driver encoder with the PCI6602 would be appreciated.
Thanks.
(3,157 Views)
Justin,
Normally, the mfgr. would include a recommended "Line Receiver" interface circuit for the encoder. I've found that some line-driver encoders actually can be successfully connected directly to the 6602 for quick-and-dirty testing, though you wouldn't want to wire that up arbirtrarily or rely on it for the long term. In any event, it sounds like you'll need to add a line receiver interface.
-Kevin P.
CAUTION! New LabVIEW adopters -- it's too late for me, but you *can* save yourself. The new subscription policy for LabVIEW puts NI's hand in your wallet for the rest of your working life. Are you sure you're *that* dedicated to LabVIEW? (Summary of my reasons in this post, part of a voluminous thread of mostly complaints starting here).
(3,143 Views)
