07-31-2018 11:02 PM
Hello.
I have problem with sequence loop. First start(USB-6525) while loop program run complete when I start(USB-6525) run again program start run normally but escape time is not reset. I need reset escape time when I start(USB-6525).
Please help to explain how I revise it.
Thanks.
Ai
08-21-2018 10:32 AM
Hi Hanna-ai
I took a look at your VI and I am confused about what you mean by escape time. It looks like you are using the Elapsed Time express VI to control how long your while loops execute. Every time you execute this code the elapsed Time should start counting once the loop executes, so it should automatically reset.
If you can better describe the actual problem in more detail, then I can provide more advice. For example, please explain what you mean by escape time. Also what functionality are you currently seeing, and what do you expect. This will also encourage members of the community to look into the problem you are having.
Michael B.
