‎02-02-2015 05:02 AM - edited ‎02-02-2015 05:05 AM
Hello All,
I have an application where I acquire counter signals from a flowmeter. This flowmeter has A and B signals like a traditional quadrature encoder.
Theese signals are wired to a PCIe-6612 counter board.
I have discovered that when I select the linear encoder instance of the "DAQmx Create Virtual Channel.vi" and set it as X4 decoder, it's not working. It behaves as a X1 counter.
I have to select the Angular encoder instance instead to have the X4 decoding working properly.
Is it a bug or a known behaviour?
Regards
‎02-03-2015 02:40 AM
I have used a linear encoder in X4 mode without any problem. However, the interface was not a counter board but a PCIe-6323 DAQ board .
The main difference is that I configure the channels with Measurement And Automation Explorer (MAX) and then use them in LabVIEW.
As a first step, I would check if the linear encoder X4 setup works in MAX. If yes, the error comes from the LabVIEW code.
‎02-11-2015 08:28 AM
Does it work ?
‎02-11-2015 08:44 AM
Sorry for my late reply.
In fact, as the angular encoder works, and this machine is on site, so I did not investigate any further.
The settings of both instances of this VI are quite the same, so I don't think there was a bug in my code.
I was just asking if someone already had the same problem with the same acquisition board.
Thanks for your help.
Regards
